New CNC Overcuts (/Dogbones) custom feature
hendrik_kueck
Member Posts: 13 ✭✭
I wrote a new FeatureScript for adding overcuts (dogbones) to all corners of a part that need them to make the part CNC machinable.
I am aware that there are existing custom features for this, but I believe this one is a bit simpler to use, and adds a couple new features.
You simply select the parts that you want overcuts to be added to and the Featurescript figures out all the corners that need overcuts automatically.
The overcuts are automatically extended all the way to the top of the part.
If desired the direction along which overcuts should be placed can be specified, and there is an option to add fillets to the ends of the overcuts (to achieve smoother CNC toolpaths).
Get the custom feature here and make sure to read the PDF documentation about how to use it and which preconditions your part needs to satisfy for the script to work.
Example of choosing the overcut placement direction:
10
Thanks for sharing!
RENDERCAD
1) Normally something like this is used when the mating part has a sharp corner. The way the FS works now, is to make the curved cut touch the theoretical sharp. I think there should be an option to make it slightly outbound of that. Something like .010" (or user defined). This would allow a part with a sharp corner, and even possible burrs, to register well, instead of possibly rocking in that corner if the machining tolerances on either part are not perfect.
2) If the tool diameter is input as the real tool diameter, there will be a dwell in the corner during the machining. Not ideal for the tool. I'd suggest a setting where the feature it cuts is a user selectable amount larger than the tool diameter. This of course can be accomplished simply by putting a bigger number than the tool diameter currently.
Thanks for the consideration:)
What happened, how come you all commented on the same day, nearly half a year after I posted this? Was it feature script appreciation day, or was it highlighted somewhere? Anyway, I definitely appreciate the positive feedback, good to know some people are using it and are finding it useful.
Nick, thank you for the feedback and the suggestions.
1) Great point, that would be a useful additional parameter.
2) Maybe I should just rename the option from "Tool Diameter" to "Overcut diameter" and explain in the PDF that this should be set to the tool diameter, or slightly larger than that to avoid the tool dwelling in the corner.
Hi Hendrik,
It could be possible to filter by grade of convexity type: concave but up to 56° for example?, I would like to aply to all concave edges except the ones that are smaller than that.
It's possible to do that?
Thanks for posting.
Sorry for the super late reply.
Since this script is about making parts CNC machinable, such a setting wouldn't really make sense, because no concave sharp corners can be CNC machined, no matter how shallow the angle.
However you can make your own copy of the script and try to have the chatbot of your choice add this setting into the code. Technically it is definitely possible and I think it shouldn't be too difficult.
@hendrik_kueck big fan of this script. It was one of the biggest changes to our company practices coming from Solidworks which has no equivalent for corner treatment. I used to do my corner overcuts with a chamfer and a hole feature centered on the span of the chamfer and this is insanely faster.
I do have my own custom copy with the only change being that if a part contains no concave edges I'll skip the body and move on to the next one in the list to overcut. Current published version will fail if you pass it a body needing no overcuts. Otherwise 10/10 feature and I'm glad to never have to apply that old 4 step solidworks method ever again.
Derek Van Allen | Engineering Consultant | Meddler@Derek_Van_Allen_BD Thank you, that's amazing to hear!
And that sounds like a very good change. I should fix that too, the script shouldn't fail on a body needing no overcuts.
