Frame Cutlist call-outs
henry_feldman
Member Posts: 135 EDU
One feature I'd love to see is an automatic labeling via the callouts on a drawing of a frame assembly linking with a cut table in the drawing. If your frame has many segments (like a cell might) it would be really handy to be able to let it automagically put call out numbers to the table on each type of frame element (maybe option first instance, all, all at same level, etc) so you can rapidly build assembly instructions. I'm sure others have encountered the tedium of calling out all the various frame members.
As an aside the row highlighting with the corresponding frame element highlighting doesn't work in the isometric view?
+1 I deal with this all the time
