What does the error EXTRUDE_OFFSET_TOO_DEEP refer to?
kenn_sebesta167kenn_sebesta167 Member Posts: 111 ✭✭
edited November 2025 in FeatureScript
Google doesn't find anything, the search term doesn't show up on the forums, and the OnShape AI assistant returns unhelpful generic suggestions.
(For context, my FS at https://cad.onshape.com/documents/1e451ed1452487dd6118fbbe/w/76456d124ce9039290f2b923/e/dd08e1728a2b2a421f293dd8 worked when I first published it and now the code pathway fails while throwing that error).
I can make guesses, but it's better to have the canonical definition documented somewhere that is indexed by the search engines.
  • EvanReeseEvanReese Member, Mentor Posts: 2,764 PRO
    I'm guessing you've somehow generated a length value that's hitting the limit of a part studio size. You can go to the standard library and hit "command + shift + f" (on mac) to bring up the super-duper find/replace tool which can search ALL of the tabs at once. Searching that error finds this.
