Help with correcting my fs please
Aly_k
Member Posts: 17 ✭
Can someone please assist in helping me correct my fs code.
FeatureScript 2815;
import(path : "onshape/std/common.fs", version : "2815.0");
import(path : "onshape/std/table.fs", version : "2815.0");
annotation { "Feature Type Name" : "Custom Part Table from Config Table" }
export const customPartTable = defineFeature(function(context is Context, id is Id, definition is map)
// Name of your configuration table in Onshape
const configTableName = "PARTS"; // Update this if your table is named differently
// MANDATORY PRECONDITION: Must check that the configuration table exists before fetching data.
precondition(hasConfigurationTable(context, configTableName), "Configuration table '" ~ configTableName ~ "' must exist in the Part Studio.");
// Get all row names from the configuration table
var rowNames = getConfigurationRowNames(context, configTableName);
if (size(rowNames) == 0)
// Table is empty, no rows to display
return;
// Collect all parts (rows) and all unique column names (keys)
var allKeys = {};
var PARTS = [];
for (var rowName in rowNames)
// Fetch the parameters for the current row
var part = getConfigurationParameters(context, configTableName, rowName);
// Include the row name as the 'Name' column if the row doesn't specify one
if (!hasKey(part, "Name")) {
part = part + { "Name": rowName };
// Collect all unique keys for column definitions
for (var key in part)
allKeys[key] = true;
PARTS = append(PARTS, part);
// --- Column Generation Logic (Ensures consistent, predictable column order) ---
// Define a preferred order for important columns to ensure consistency
const PREFERRED_KEYS = ["Name", "Desc", "Material", "Length", "Diameter", "Width", "Height"];
var columns = [];
var processedKeys = {}; // Keep track of keys we've already added
// 1. Add preferred keys that exist in the data
for (var i = 0; i < size(PREFERRED_KEYS); i++)
var key = PREFERRED_KEYS[i];
if (hasKey(allKeys, key))
columns = append(columns, tableColumn(key));
processedKeys[key] = true;
// 2. Collect remaining unique keys
var remainingKeys = [];
for (var key in allKeys)
if (!hasKey(processedKeys, key))
remainingKeys = append(remainingKeys, key);
// 3. Sort the remaining keys alphabetically for deterministic ordering
remainingKeys = sort(remainingKeys, comparator());
// 4. Append the sorted remaining keys
for (var key in remainingKeys)
columns = append(columns, tableColumn(remainingKeys[key]));
// --- End Column Generation Logic ---
// Build table rows dynamically using the collected PARTS data
var rows = [];
for (var part in PARTS)
var row = [];
// Iterate through the determined, ordered columns
for (var col in columns)
var colName = columns[col].name;
if (hasKey(part, colName))
row = append(row, part[colName]);
else
row = append(row, "—"); // Empty if part does not have this property
rows = append(rows, row);
// Create the custom table
table(id + "PartTable", {
"columns": columns,
"rows": rows
I don't seem to understand what I am doing wrong these are the errors I am getting.
this fs will be used to reference certain things from a configuration table and turn that info into a custom table for me so I can insert that table into a drawing.
one thing:
i += 1
then there's something wrong with the precondition definition. But i haven't programmed tables before so i'm not sure what.
BUT if you add
precondition{} before the function block, and comment out the existing precondition line,
There are still a bunch of functions that aren't recognised…
ahh I see thank you!
