cloud hardware
2»
    edited September 2015
    Where I notice a lag is when I dimension drawings. Typically I have to wait to input the dimension or I'll get 75 inches instead of 3/4 inches.
    @don_howe The lag is from a performance issue that is not local to your machine, I believe.  It's between Graebert and Onshape somewhere...  No matter of local hardware will change that at the moment.  It actually has gotten quite a bit better since I first used it.  They are working on it and making improvements.  Keep in mind, this is still Beta we're talking about, and improvements have been coming pretty hot and heavy as of late.
  • teddy_pessagnoteddy_pessagno Member Posts: 38 ✭✭
    The Chrome box is doing great.
    Still want to upgrade this computer.
    Which of these two cards do you all recommend?
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814133542
    or
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814133543
    I was looking at the cuda cores, memory interface , and the core clock. Thats where I got confused.
    Thanks
    Teddy_P
    edited November 2015
    I'm not sure either @teddy_pessagno .  If I had to guess, I suspect more VRAM would be better, but the card with 1GB of VRAM is DDR5 compared to 2GB of DDR3.  By them both and try them both, then return one... if possible?  Let us know.  Maybe there won't be enough of a difference...  Drivers compliant with WebGL is also important.  I would think with new cards this is not an issue.
