Onshape Stuck not showing feature tree
mskeelsmskeels Member Posts: 6
Hi,
While modifying a dimension on a part, onshape suddenly froze up as seen in the screenshot below along with the following error:
Onshape encountered a problem with your last operation. If the problem persists, contact support. Support code 59a13a3290a2cb860f3e8c0a.
I am unable to access the feature tree. It seems to be stuck in an endless loop. My other OnShape documents are fine — just seems to be this one. Changing the version doesn't do anything. I've reached out to OnShape support but this CAD model is critical and trying to get a new print on tonight. Any help much appreciated :)
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,933 image
    Close the doc and wait 10 minutes. If that doesn't resolve it, try going back before you modified the circle (you can do this while the doc is closed - from the docs page, select the doc and open the version graph on the right side panel, then go to the previous microversion).
