Convert Cutlist to BOM
Jordan_RozendalJordan_Rozendal Member Posts: 7 PRO
Good Afternoon
I think it would be convenient if we could convert existing Cut Lists to BOMs so we can tie them to Assemblies/Part Studio Assembly Drawings. Being able to call out where what component goes where on an image of an assembly level component would be greatly helpful.
  • martin_zmartin_z Member Posts: 2
    Hi, I would also really benefit of this option, being able to have a cutlist with qty used, of any selected assembly/BOM. Does anyone have insight on this?
    I'm into complex Sheetmetal/steel frame designs.
  • MichaelPascoeMichaelPascoe Member Posts: 2,803 PRO
    edited December 2025
    You can do this with Cut list+. It will attach the cutlist data to different properties that can be viewed in the assembly bom or drawings.
    If you need it customized, feel free to reach out.
    Custom features can only go so far. There is another way to do it with Assembly Imposters (Feature + App) if you want a more official BOM way to do it if your company systems require that.
    RENDERCAD
