Align sketch to to plane, how to?
mike_t532mike_t532 Member Posts: 5
How to match center of sketch to center of plane?
  • robert_scott_jr_robert_scott_jr_ Member Posts: 699 ✭✭✭
    Hello Mike. The plane shown has edges that don't really exist. Any plane is infinite. So, having the plane and centered to each other doesn't matter. A plane can be used for other operations such as Split, Mirror, etc. so an image of it to see its position relative to other elements may be needed. However, if it may be visually appealing, I've found that exiting the sketch and opening it again for editing often results with the bounds of the sketch and the visible plane being centered to each other. - Scotty
  • mike_t532mike_t532 Member Posts: 5
    you are right, it's just a visual thing. It's annoying, but the final part still works fine
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,937 image
    Use the origin as a center point
