How do I rotate the sheet 90° in a drawing?
mi_sgmi_sg Member Posts: 2
Do to the shape of some parts, sometimes it appropriate to use a sheet in vertical (portrait) mode.
Is there a way to do this with onshape?
  • glen_dewsburyglen_dewsbury Member Posts: 1,295 PRO
    You would need to make your own drawing template. OS has some references to start from for boarder format then you'll need to copy your own title block.
