Export/Import Class with assets feature request
CoreyCorey Member Posts: 10 EDU
I believe it would be useful if there were a way an educator could export a classroom to share with colleagues and other educators. If I set up a training or classroom with assignments and documents as assets, it would be nice to be able to share this without the need for the other educator to rebuild the classroom and assignments.
This would be similar to the Clone Class but would need to export the metadata and resource files to share. I suspect this would require a way to bind the resource files to the Class vs currently they are in a general folder in the Educators Account.
  • Ste_WilsonSte_Wilson Member Posts: 545 EDU
    edited December 2025
    What happens if you invite/ add them to the classroom. Do they have educator permissions in it? It's something I've been meaning to check for a while!
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 865 PRO
    Exporting a Classroom wouldn't exactly work, because a Classroom contains users and documents. But I like the idea of being able to clone Classes into another Classroom. So, if Mr. Adams and Ms. Brown were both educators in each other's Classrooms, they could share Classes, along with assignments and assignment docs.
