Property Manager (Free App!) 🛠️
MichaelPascoe
Member Posts: 2,736 PRO
Property Manager
A project property manager. Useful for setting bulk properties.
While this is a full tool, it is only a small sample of whatÂ
CADSharp is capable of automating for you.
Property Manager is a sub-app from within the CADSharp Toolbox app.
Once you get the app, don't forget to grant access to the app within your user settings:Â https://cad.onshape.com/user/applications
  Get it now! Â
How does it work?
It allows you to manage properties across multiple documents. Data is stored within variable studios for easy access.
- While inside a document, start the property manager sub-app.
- If there is no variable studio data, this will create it now.
- Enter the url's of the documents you want to manage.
- Within the property manager, you can add existing properties to the list.
- Once you have added or modified the properties in the list, your ready to click "Set all properties"
How to use Property Manager
Special thanks to CADSharp for sponsoring this app and to @CarlGutierrez for allowing us to re-work the original Property Manager into the toolbox .
If you need custom apps, custom features, or any kind of Onshape training, check out cadsharp.com
Learn more about the Gospel of Christ ( Here )
CADSharp - We make custom features and integrated Onshape apps!  Learn How to FeatureScript Here 🔴
Oh, I thought this was to help me with my real estate business.
That coud be helpful in certain cases and to keep project properties clean.
