Extrude along a line featureScript
isaac_brown497
Member Posts: 2 ✭
I'm trying to create a feature that allows me to easily create print-in-place hinges for a personal project.
One of the features is that I can define the angle the hinge is created at. how can I edit my script to make the extrudes occur along the same path as the line given?
Here is the document:
https://cad.onshape.com/documents/41bdb6a292a2dc04a4071116/w/992bbe18a10d9513db5854fa/e/f1d0eb7fac53ba87787ca4ca?renderMode=0&uiState=695d12b426f228db2007ad69
To extrude a shape along a line you can use opSweep(), but I don't see any reason to use that on a hinge.
Looks like you just need to draw your other hinge plate shapes and extrude them.
Can you provide a fully modeled example of what your trying to do? It's always best to prototype your feature before scripting away. You can often save a lot of FS steps by simply modeling it better before you start the feature.
Here are the best places to learn how to use FeatureScript:
RENDERCAD
like Michael said. featurescript may be overkill for this situation.
If you create a fully configurable part studio that allows robust hinge creation, you could then insert them into assemblies, or even part studios using the derive or even amalgamate custom feature.
