+1 @TooTallToby to get in here. As per the rules, no Ivan exploits!
Ramon Yip | glassboard.com
Someone needs to model the whole thing with a custom feature that has no UI and only makes this exact part. (with math, not imports obvs)
Technically, that feature has zero opBoolean usage whatsoever. What it does is smuggle illegal sheet metal geometry into the 2d flat pattern view from the 3d view and skips all the manufacturing checks of the normal engine. Subtractive operations on planar surfaces only.
Don't tell the devs.
Derek Van Allen | Engineering Consultant | MeddlerSo I should have mentioned in the initial post, but my method for checking for same-ness of the initial input part is to run a matching bodies query with Query Variable Plus, which has more robust geometry evaluation than pure mass properties evaluation.
Derek Van Allen | Engineering Consultant | Meddler@Derek_Van_Allen_BD: got those forbidden Booleans taken care of. it was painful in one instance, just as you intended!
