Two Lofts conjoining, how to remove parts so it creates a "Y" tube.
john_trotto910john_trotto910 Member Posts: 11
I have two lofts that I have created with loft thin command , one from the left curved to a center hole, and one from the right curved to that same center hole.
I need to remove the parts inside them so that the inside of the "Y" shaped tube they create is hollow.
Not sure the best way to go about this.
Or, is there a better way to create a single loft with 3 holes? (from what I could tell you cant do that)
Section View
