What the correct ${............} convention to be able to export the name of a configuration?
paul_masser
Member Posts: 19 PRO
in General
I want to set an export rule with this to uniquely name each config on export.
Thanks in advance,
Paul
I just worked out what was wrong. I'd named the configs in the configured properties tab and not changed the configuration to apply them to the second part that I'm exporting…
