Hidden exploded items showing in drawings but not in assembly?
henry_feldmanhenry_feldman Member Posts: 135 EDU
I have an extra screw apparently in my assembly's exploded view, and it is hidden on the assembly (good) as you can see:
However in my drawing with that view inserted the screw shows back up?
  • S1monS1mon Member Posts: 3,985 PRO
    Have you updated the drawing?
    Do you need/want the extra screw in the assembly? Hide/show is not a great way to manage a BOM.
  • wayne_sauderwayne_sauder Member, csevp Posts: 641 PRO
    Agree with @S1mon, however, if you need the screw for some reason and just want it hidden in the drawing, you will need to look into display states.
