How to create a blank ARES Kudo DWG without importing .dwg first
Hi all,
I would like to create a blank DWG in ARES Kudo directly from Onshape without first importing a .dwg file.
Current + menu Only “Create Drawing…” (Onshape drawing) and “Import…”.No “Create ARES Kudo sheet ” or “ARES Kudo” under Applications.
What I have:
  • ARES Kudo subscription.
Goal:
  • Click + → open blank ARES Kudo DWG (Model + Layout1)
  • Add new sheets via New Layout
Question is there a way to:
  1. Add “ARES Kudo” application to appear in the application menu
  2. Use FeatureScript to generate a blank DWG/DXF in ARES?
Thanks!
  • Chris_BeckettChris_Beckett Member Posts: 22
    Did you find the answer?
    If not, I'm wondering if you'd have to get their Desktop subscription called Ares Commander to do that.
  • Ste_WilsonSte_Wilson Member Posts: 554 EDU
    This sounds like an Ares Kudo problem. Have you reached out to them? My experiance with their support team has been good so far.
    I think I've asked this question of them a while ago, as it seems the obvious thing to be able to do and the answer was 'no'.
    Perhaps have an onshape doc set up with a blank dxf and then copy that as your base?
