thin extrude on part edges
DragonaireDragonaire Member Posts: 2 EDU
requesting the ability to use a then extrude on the edge of a part, as simulated above with an intermediate sketch
  • tom_augertom_auger Member Posts: 129 ✭✭
    Oh my, yes. I don't see why there is more use cases for thin extruding a face (which would then produce two solids) over thin extruding an edge, so definitely my vote for this as well!
    @s1mon is there a way to see whether this has already been submitted and to vote for it?
  • S1monS1mon Member Posts: 4,094 PRO
    It would be hard to say that it's never been posted, as the search tools are only so good, but I did this search and didn't find anything that seemed to cover it.
    https://forum.onshape.com/search?adv=1&search=thin+extrude+sketch&title=&author=&cat=24&subcats=1&tags=&discussion_idea=1&discussion_discussion=1&comment_comment=1&discussion_question=1&comment_answer=1&discussion_poll=1&within=1+day&date=
  • MDesignMDesign Member Posts: 1,342 PRO
    I accidentally tried to do this today not realizing it wasn't possible. LOL
  • jelte_steur_infojelte_steur_info Member Posts: 655 PRO
    I usually end up using this custom Extrude feature:
    It did thin extrudes way before the native feature could. It also allows for extrusion of non planar faces, edges and curves.
    Quite useful, i find myself using it often.
  • jason_1jason_1 Member Posts: 30 PRO
    Yeah I do this somewhat frequently too. I'll click a face and extrude that (works fine) and then realize it should just be a wall of constant width instead but you can't select faces or edges and use thin extrude. Making a sketch and using "use" is never as robust
  • jeff_mcafferjeff_mcaffer Member Posts: 98 ✭✭✭
    Anyone know if this ever got logged? I redid the search that @S1mon posted above and didn't see anything particular. I stumbled on needing this today and couldn't figure out what I was doing wrong. Turns out it's not supported.
    As an alternative is there a way to create a "curve" or an "edge" from the edge of some faces or some such? One could do that, pick the edges they want to coalesce into a "curve" and then thin extrude that.
    FWIW, the custom extrude feature @jelte_steur_info mentioned works for my current scenario. Does seem however that this should "just work" in the normal Extrude feature.
