Improvements to Onshape - January 30th, 2026
2»
  • EvanReeseEvanReese Member, Mentor Posts: 2,807 PRO
  • S1monS1mon Member Posts: 3,941 PRO
    I know that on iPad/iPhone we're supposed to use the iOS apps. However it seems like we're getting very close to just being able to use the web version. What I can't seem to get to work in iOS Safari on my iPad (latest iOS on M2 iPad):
    1. I can't figure out how to manipulate the rollback bar. I've tried tap, double tap, Apple Pencil… ?!?
    2. I can double tap with a finger to edit/open etc. but I can't figure out how to do get those things to happen with the Pencil.
    3. Onscreen keyboard entry seems like it needs an extra click to open. (I don't have a iPad physical keyboard, but I can probably set up a BT keyboard to test)
    The Pencil is really cool with how you can hover and then click on sketch entities and drag them around (assuming they're not constrained.
    I know Onshape doesn't usually comment on long term plans, but getting a full version of Onshape (including drawings and FS editing…) is really amazing.
    Do we need different nav settings per platform? FWIW, I have 'Solidworks' as my preferences/mouse controls/view settings.
  • aris_setyawanaris_setyawan Member Posts: 11 EDU
    the great update lofted sheetmetal. 😀
  • paul_hendrik_maraispaul_hendrik_marais Member Posts: 2
    This makes me so happy! Finally sheet metal lofts
  • karel_workskarel_works Member Posts: 20 PRO
    This is really big update. thank You Team for such a great work! Now let me play with all that new stuff:)
  • christian_pettychristian_petty Member Posts: 83 PRO
    Getting close. I am able to move the rollback bar using Continuity or a case that has a trackpad for now. It would also be nice to hide the app store banner.
    Christian Petty - Mech. Design Engineer, Radian R&D
  • Matt_LoMatt_Lo Member, Moderator, Onshape Employees Posts: 16 image
    @S1mon The changes with this release is to allow for graphics manipulation of a part or assembly, mainly set up for computers with a touchscreen. This is why using the feature tree and using a stylus isn't really working. There are future plans to implement full touch support across the software.
    Fantastic. It's getting tantalizingly close already. I'm sure there will be a zillion little things to tweak, but it's great to see stuff moving in that direction.
