Why is this sketch not fully defined?
lizardonabikelizardonabike Member Posts: 6
edited February 5 in Community Support
What am I missing here to fully define this sketch? This often happens to me when working with the arc tools.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 916 PRO
  • CADNurdCADNurd Member Posts: 66 ✭✭
    Arcs are segments of a circle and circles need to be given a size. Also, if you're planning on extruding something with ready-made fillets, that's generally not the way to go. Fillets are better added to the solid model at the very end.
    Unemployed Onshaper - operating on European time. More of me here ➤ https://linktr.ee/Liam.G
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,058 PRO
    Put the dim to the flats of the box, not to the tangent points of the radii. That is the design intent 99.9% of the time. Then, put a separate dim for the radius. Set both radii equal to each other.
    I also agree with the comment to add the radii as a separate feature in 3D, instead of inside the 2D sketch, as a general cad principle,
  • jim_zamecnikjim_zamecnik Member Posts: 12
    Constraints, and coincidence between sketches has been the biggest challenge for me. I spend literally hours sometimes trying to figure out why a sketch won't turn black or a loft won't render. I haven't found a good tutorial or YouTube on troubleshooting these situations. I've only been working with Onshape (and 3D CAD at all) for a week; I knew it wouldn't be easy but hopefully a breakthrough is coming!
    CAD is about impossible to pick up fumbling around, like you might be able to do in a word processor. Do the training built into OS right from the source. It’s excellent and free.
  • lizardonabikelizardonabike Member Posts: 6
    @CADNurd I am planning on using the loft tool along the path of that arc. Would you still recommend adding the curves after? I have done some experimenting with the sweep tool around curves and was having bad geometry issues.
    Thank you, @Matt_Shields, I see what I am missing now.
    @lizardonabike - I would say that if it's something that can be done with the fillet tool then add it after. Otherwise, do whatever works to give you the exact shape you're after.
