Why is this sketch not fully defined?
lizardonabike
Member Posts: 6 ✭
What am I missing here to fully define this sketch? This often happens to me when working with the arc tools.
CADNurd
Member Posts: 64 ✭✭
Arcs are segments of a circle and circles need to be given a size. Also, if you're planning on extruding something with ready-made fillets, that's generally not the way to go. Fillets are better added to the solid model at the very end.
Unemployed Onshaper - operating on European time. More of me here ➤ https://linktr.ee/Liam.G
Put the dim to the flats of the box, not to the tangent points of the radii. That is the design intent 99.9% of the time. Then, put a separate dim for the radius. Set both radii equal to each other.
I also agree with the comment to add the radii as a separate feature in 3D, instead of inside the 2D sketch, as a general cad principle,
Constraints, and coincidence between sketches has been the biggest challenge for me. I spend literally hours sometimes trying to figure out why a sketch won't turn black or a loft won't render. I haven't found a good tutorial or YouTube on troubleshooting these situations. I've only been working with Onshape (and 3D CAD at all) for a week; I knew it wouldn't be easy but hopefully a breakthrough is coming!
https://learn.onshape.com/learn/course/fundamentals-sketching/
CAD is about impossible to pick up fumbling around, like you might be able to do in a word processor. Do the training built into OS right from the source. It’s excellent and free.
@CADNurd I am planning on using the loft tool along the path of that arc. Would you still recommend adding the curves after? I have done some experimenting with the sweep tool around curves and was having bad geometry issues.
Thank you, @Matt_Shields, I see what I am missing now.
@lizardonabike - I would say that if it's something that can be done with the fillet tool then add it after. Otherwise, do whatever works to give you the exact shape you're after.
