OpLoft Fails
thomas_fieguththomas_fieguth Member Posts: 5 EDU
Hello,
I am trying to do an opLoft, and it fails, giving me the following error:
@opLoft : LOFT_SELECT_GUIDES
I am initializing the loft in the following way:
opFitSpline(context, id + ("outSpline" ~ edgeId ~ "Face" ~ faceId), {
"points" : outPts
opFitSpline(context, id + ("inSpline" ~ edgeId ~ "Face" ~ faceId), {
"points" : inPts
opLoft(context, id + ("ellipseLoft" ~ edgeId ~ "Face" ~ faceId), {
"profileSubqueries" : [ qSketchRegion(id + ("startSketch" ~ edgeId ~ "Face" ~ faceId)), qSketchRegion(id + ("endSketch" ~ edgeId ~ "Face" ~ faceId)) ],
"guideSubqueries" : [qCreatedBy(id + ("outSpline" ~ edgeId ~ "Face" ~ faceId)), qCreatedBy(id + ("inSpline" ~ edgeId ~ "Face" ~ faceId)), faceEdge]
I have done the loft manually (manually selecting all 3 edges that the opLoft would use) and it works
Thanks in advance
  • S1monS1mon Member Posts: 3,985 PRO
    I highly recommend using @jnewth’s viz() and dbg() with his Report feature. Debugging queries is very challenging without being able to see what each step looks like. Also showing the count for the items in the query.
    https://forum.onshape.com/discussion/29653/use-report-viz-and-dbg-for-conditional-println-and-debug-visualizations
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 375 image
    What @S1mon is correctly pointing out is that you should verify that all of your queries, e.g.
    and
    faceEdge
    actually exist, are of the right type, and follow the rules (Each guide curve should intersect each profile once.)
    Using the Report feature is a great way to do so….
  • thomas_fieguththomas_fieguth Member Posts: 5 EDU
    hmm, ok thanks for the advice. I haven't figured it out yet, but these tools will definitely help.
    I can confirm that they all exist and that the types are correct:
    Sketch region 1 { featureId : [ FgBIysKu6rXgK3O_0 , startSketch2Face0 ] , filterInnerLoops : false , queryType : SKETCH_REGION }
    is type FACE 1
    Sketch region 2 { featureId : [ FgBIysKu6rXgK3O_0 , endSketch2Face0 ] , filterInnerLoops : false , queryType : SKETCH_REGION }
    is type FACE 1
    Out Spline { featureId : [ FgBIysKu6rXgK3O_0 , outSpline2Face0 ] , queryType : CREATED_BY }
    is type EDGE 1
    In Spline { featureId : [ FgBIysKu6rXgK3O_0 , inSpline2Face0 ] , queryType : CREATED_BY }
    is type EDGE 1
    Face Edge { queryType : TRANSIENT , transientId : JGJ }
    is type EDGE 1
    Also, I'm pretty sure that the points are coincident on the sketch plane because I defined them as such:
    skPolyline(startSketch, "polyline1", {
    "points" : [
    vector( 0, 0) * inch,
    worldToPlane(startSketchPlane, inPts[0]),
    worldToPlane(startSketchPlane, outPts[0]),
    vector(0, 0) * inch
    I guess there is a chance that the spline points (outPts[0] and inPts[0]) are not actually on the plane and are just being projected onto the plane? That being said, visually it looks correct, and again, when doing a loft manually with those selected edges, it works. I'll keep working at it. Let me know if anyone else has any ideas.
    Thanks again
    Are you trimming the guides/profiles? In the regular feature I believe it defaults to doing that.
