Lower a plane/sketch?
jim_zamecnikjim_zamecnik Member Posts: 17
I'm trying to close this gap between the fin and fuselage. I tried offsetting plane 7 where the "fin root airfoil" sketch exists, without success. I tried using "split" as I saw in a youtube tutorial (24:15) but couldn't get that to work either. Any pointers are appreciated. Thanks.
-Jim
https://cad.onshape.com/documents/df6b19e1161c806989e03981/w/75b667e469169c2bb331f91c/e/8c0c14baf6ef0fc63f12acd0
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 930 PRO
    A simple Extrude "to next" works.
  • jim_zamecnikjim_zamecnik Member Posts: 17
    Damn, that was easy! Thank you Matt.
    I worked around it by covering it with a Face Blend fillet, but that brought new complications….as you'll see in tonight's question 🙄
    I should probably roll back and do this, then start over with what I've been doing tonight
