CAD Video Tips?
For those of you that produce regular content for YouTube etc.
What tips and tricks can you offer about how to set up your Onshape environment and screen recording tools?
I assume that most videos are recorded at 1080p resolution for ease of viewing on most monitors. I assume that higher resolutions could make it hard to see the icons and read the text.
I'm on a Mac. If you have specific tools or settings there that might be helpful….
I've already heard from @EvanReese that is super helpful for editing.
Any other thoughts?
Are we gonna get tutorials from the one and only @S1mon in the near future???
The only nugget I have to offer is that I've used Loom to record short videos for the office.
Ramon Yip | glassboard.com
That's the plan. I'm busy working on a very powerful plastic boss custom feature, and it seems like a video intro is probably in order. I also want to do similar intros for some other features I've been working on.
Now that I have my new computer set up with Win 11. I see the snip tool upgraded to record video as well. The issue is trying to post. It makes a mp4 file that won't post. What's the best way to convert this to one of the file types listed below.
Looking forward to seeing what you make!
No tips, just enthusiastic encouragement from my side! I always love to see some workflows tips/tricks from other advanced Onshape users! Would also love to see some of your more advanced surfacing models or tips/tricks explained if you ever get to it…
I saw your post in the thread about solidworks vs onshape surfacing and was impressed!
If you ever stray to the dark side that is a windows PC I found OBS Studio a useful free bit of software. Available from portable apps.com
I see Alins has already suggested that!
OBS is also on Mac and Linux. I use it to live stream pool matches from my Mac.
I’ve only made a few edited videos of some CNC/OS related stuff. The main thing I’d recommend is editing them a few times to remove all the dead space, filler words, “umm”, etc. Also don’t repeat anything. If you did while speaking, edit out the worse of the two.
All of the above makes the final product shorter and much more watchable.
This info was from a video I saw from a channel that had millions of views about “how to make a video”. Those points were some of its main takeaways.
If you have a high resolution monitor, zoom in your browser a bit, and make your cursor a bit bigger.
People watching your video are not seeing it at the same size as you.
You're telling me the 37" ultrawide isn't standard issue? How is everyone else keeping WoW loaded in the corner of their screens then?
Derek Van Allen | Engineering Consultant | Meddler@S1mon I'm pumped! You're there with Descript for recording and editing. I echo Alnis though. Sound matters more than anything else pretty much. Descript does also have some AI audio enhancer that usually makes it sound a notch or two better. Earlier on I ran into a bunch of aspect ratio mismatch when just screen recording my macbook display, but I started using an external monitor and the 16:9 aspect ratio at full screen is a perfect match for Youtube, so there aren't any black bars needed to fit the whole thing. You can also go full screen with Onshape in Chrome with command+shift+F. I imagine other browsers have a similar function.
