Split Panel Feature
Caden_ArmstrongCaden_Armstrong Member Posts: 391 PRO
This split panel feature has been one of my favourites of the past year to work on. The combination of a really cool data structure, and an interesting implementation of point manipulators have resulted in a feature I would describe as "playful". Clicking a blue dot adds a split, a red dot remove the split. The extra cool part? The splits aren't limited, you can add as many as you want - with any level of complexity. This feature made me rethink the options for user experience in a custom Onshape feature.
One thing I have struggled with is how to rewrite the feature into a generic use case. I'm not sure how it can be helpful to a wider set of users. So I'm just leaving it essentially as a demo. Hopefully it will inspire some new workflows, or you can use it to show your team the great potential in Onshape.
Try it out here
  • MichaelPascoeMichaelPascoe Member Posts: 2,772 PRO
    Using the point manipulators to activate an operation looks pretty responsive.
    I could see something similar being useful for curve splitting or even a quick part slicer. @EvanReese's ffs has something similar.
  • S1monS1mon Member Posts: 3,970 PRO
    This is a cool UI.
    I could see a version of this where instead of dimensions, there's a ratio.
    I could also see wanting to have a gap added at each split for tolerance reasons.
    For cabinetry (and other things) being able to quickly split a panel into multiple equal pieces with equal gaps would be great.
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 717 PRO
    @S1mon the sudden realization that I need to make biscuit joinery amalgams for some of our parts that we never annotated on drawings before because it was too annoying to draw.
