Help Locating "Collaborative" 3rd Party Manufacturers...
miko_cardenas
OS Professional Posts: 17 ✭
Just curious if Onshape has a list of possible CNC plywood furniture manufacturers who are actively using Onshape? I've looked through the forum to see if there's any reference to this resource to no avail...I live in the New Hampshire and trying to source a local manufacturer (Boston, or Manchester???).
pete_yodis
OS Professional, Mentor Posts: 666 ✭✭✭
@miko_cardenasI have used mfg.com before and quite successfully. They are a valuable resource. I've located houses that machine plastic parts, sourced screw machine parts, located plating companies, and investigated injection molded parts.5
This discussion has been closed.
Saplingstore.com
If you found me from 'a list of Onshape shops' how would you like us to proceed?
Would you like to send me an email first or would you like to have built-in function to share/quote with a shop of your choice?
matthew_menard my priority would be a shop that is local and that can produce a quality product at a reasonable price within a reasonable time frame. I realize it might be wishful thinking to expect that they use Onshape but I just wanted to put it out there in case, in the slightest chance, there was one nearby.
pete_yodis thanks for the resource. It looks somewhat promising. Have you used mfg.com before? If so what kind of result did you have?
Miko
