About slicing a form
bruce_price
Member Posts: 20 ✭
I've made a 1/2 a vase form using the loft and shell function. I would like to 'take it apart' to make a cookie cutter for each facet . What's the best way to accomplish this? I looked into slicing, but it only seems to cut it along a plane crossing, cutting through the entire object. This is the simplest form, like this, I'm working on.
https://cad.onshape.com/documents/b8bad6fbc4fd8dfe5546be8c/w/25a1049ada79a5ba6e09d140/e/865ec2d6a433dbe283d1f7d6?renderMode=0&uiState=698fa230f059ee7d75096c4e
Your facets are not actually flat - which might be a problem. You could try looking at the 'Flatten Surfaces' tool - https://cad.onshape.com/help/Content/View/analysis_tools.htm?cshid=showFlattenSurfaces#Flatten
Unemployed Onshaper - operating on European time. More of me here ➤ https://linktr.ee/Liam.G
