chadstoltzfus@premiercb.com
If it is native cad then the user simply should be able to select face(s). The program would get all the holes features. The program would bounce this off a tool/procedure table and CAM. The CAM would include all spot/chamfer, drill, tap, c'sink, c'bore code.
I did it, and it works great! I do only use bottoming form taps. It gets more complicated in a more generic enviroment where you can have different taps/materials, the user left no clearance, drill/tap too deep, etc. I think the important part is if there is no tool/procedure the program catches it early on. We can thread mill to no clearace, or order special taps/drill and add it to the tool/procedure as non-standard.
RENDERCAD
it's a shame the CAM module is not available for hobbyists as it would bring in a lot of feedback which it seems the current CAM module needs. Another reason is that at present many users design in OnShape and CAM in fusion (particularly hobbyists) and giving access to the module would potentially stop them from being Autodesk customers once they are ready to make the leap from hobby to income.
