First time . Created Project but Toolbar doesn't have Rectangle or Circle or Line. How do I turn on
dave_burchdave_burch Member Posts: 3
    You start by inserting a sketch on a plane (should be the first icon after the undo/redo). Then the sketch toolbar will come up while the sketch is active.
    https://cad.onshape.com/help/#simpleexample.htm?TocPath=Modeling%20in%20Onshape|_____1
    tip: if you press "N" you will get a view normal to your sketch.
  • dave_burchdave_burch Member Posts: 3
    THANKS. HAVE GOT THE CIRCLE ETC. drew the circle I wanted. But the circle line toolbars go away and I have to do the N again each time I want to use them. I will practice for a few hours and see if I get better.
    Yep I am plowing thru the Tutorials now and its a better way, Thanks again
