Frame trim
kevin_mason558kevin_mason558 Member Posts: 67 PRO
I have a grid of frames
Without having to draw each segment separately I thought I could use the frame trim.
this won’t work as it wont remove the intersections and keep both sides
sketch and extrude then won’t allow the parts to fill into a cut list as it can’t determine the ends.
Is there an easier or quicker way to do this other than separately adding individual frame sections?
  • MichaelPascoeMichaelPascoe Member Posts: 2,804 PRO
    You can do multi frame trimming with Frame Trim+ using the body trim option.
    RENDERCAD
