PointsManipulator/TogglePointsManipulator Size?
S1monS1mon Member Posts: 4,035 PRO
Is there some reason that a points manipulator would be smaller when there's only one? Is this a bug or intended feature?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,979 image
    I've often wondered… 🤨
  • S1monS1mon Member Posts: 4,035 PRO
    Hmmm. If it seems weird to you too, then honestly it seems like a bug. Should I report it?
    edited February 23
    Yes please. I did not know what caused this so thank you for working out it was the number of visible points.
    EDIT: I like the bigger points…
