Looks like a bug
a_r077
Member Posts: 2 ✭
Not sure is it a right place to report, but If you try to divide 1mm/1mm you will get 1mm2, expected 1 without mm
It does look like a bug, but behind the scenes this is expanded as 1 * mm / 1 * mm = 1 * (mm/1) * mm = 1 * mm * mm
Use either 1mm/mm or (1mm)/(1mm)
