copy features inward radially.
colin_king506
Member Posts: 53 ✭✭
My goal is to copy the shown features inward radially to form a grid pattern similar to open grid pattern used on industrial walkway. BTW, this 1/87.
Thank you in advance for your assistance in this matter.
Have done this linearly
You could do this with an iterating circular feature pattern which would take some time to set up.
Or you could do it much faster with @EvanReese's Speaker Pattern feature.
RENDERCAD
The Speaker Pattern feature is for round holes. I need to do it with square holes. Is there a video that goes step-by-step tutorial?
I drew the basic shape (on a existing 'disk' [circular with thickness]), extruded it (removed), Then did a Circular pattern by feature.
Interesting, the "main" in the speaker pattern allows selecting your own body but the last "version" doesn't seem to have that option yet!
I wonder if @EvanReese forgot to create a new version or if it's not quite ready for primetime?
I think this will help.
https://learn.onshape.com/learn/course/advanced-part-design/advanced-features/exercise-vent?page=1
In the meantime, here's a way to do this manually:
https://cad.onshape.com/documents/51fe6c780915193df1d4115c/w/770c6e82ad081367eee19aa6/e/29c46b5648abe5d3af3e2962
Here are some videos on the general idea of using patterns of sketches and variables to achieve these things (this is part one of two):
oops, funny I checked the code to see if that was available before posting, but didn't actually use the feature. 😶
RENDERCAD
I got by just doing plain linear.
That looks quite different from what you were originally asking.
If this is all you needed, I would recommend looking at the "fill pattern" FS as it can automatically eliminate cuts that go over the "edges"…
https://cad.onshape.com/documents/57361ad4e4b00e5012c3857c/v/e2b54c2409bbaaf196a9fcc9/e/14aa44d127806651b248b9c6
https://cad.onshape.com/documents/51fe6c780915193df1d4115c/w/770c6e82ad081367eee19aa6/e/b645085004adb9d4bf7ebc53?renderMode=0&tangentEdgeStyle=1&uiState=69a0cf78c4881d979eb06b8f
It seems not needed now, but @eric_pesty thanks for pointing that out. I versioned again. I've not touched that code in years, but meant to at least ship the latest.
