Centering DXF on face
Hey! My goal is to put an image on a face and remove-extrude it. For this, I have an SVG file that I have converted into DXF. The problem happens after importing the DXF, when I try to center it on the face. Adding a dimension between any part of the image and a point on my object causes the lines of the image to break apart, completely destroying the image. I'm able to remove-extrude the image just fine, but I have no way of centering it. Any idea how I can fix this?
Thanks in advance! Video and image files are available
https://youtu.be/_5AxvZupbqg
  • glen_dewsburyglen_dewsbury Member Posts: 1,288 PRO
    Place a point that you want as center of dxf. Select all and use the transform function. Move the triad to the new center and drag to origin,
