Sheet metal adding weird extension to my part...
avner_piperbergavner_piperberg Member Posts: 4 EDU
Hi there,
I trying to mock a drone and to build it from cardboard. I have a laser cutting machine that I will export DXF from Onshape. I built the part, and with Sheet metal, I used the Convert option. I wonder why the sheet metal add this two long beams at the back of my plane. Any ideas what I am doing wrong?
Thanks
https://cad.onshape.com/documents/608fc2af26fb3e851128e043/v/d969d381fb0698cd1a27de1e/e/8b62d02f72f6dbaaf4429823?renderMode=0&uiState=69ac7e4e2f678833ca3968e2
  • SMURFCADSMURFCAD Member Posts: 54
    Change the document so we can copy to help diagnose?
  • avner_piperbergavner_piperberg Member Posts: 4 EDU
    edited 2:09PM
    Hi,
    You can copy it.
    https://cad.onshape.com/documents/608fc2af26fb3e851128e043/w/4e591d7e51d765266255e27c/e/f7f16a906f5ed5c287e1ab8d?renderMode=0&uiState=69aed3fc49946a0631f39395
    Please try again, maybe from this link?
