Configuration Hypothesis: When to Use Multiple Fixed Parts
brandon_nichols678brandon_nichols678 Member Posts: 13 ✭✭
edited March 8 in General
Wrestled with this one for more than a few hours, trying different approaches to obtain RH and LH versions of the simple assembly.
Like for example, duplicating the LH and rearranging parts to obtain the RH. All looked good, except the BOM did not roll up identical parts from different assemblies — and while I was able to configure my way out of that problem today, this does not bode well for BOM aggregation of many different subassemblies, all using a variable mix of the same identical bolts, washers and nuts. More on that later, if necessary…
Back on topic, consider this 'Configuration Hypothesis': If an assembly's fixed part needs to move (in this case flip) for different configurations, then use another instance (also fixed) of the fixed part, and suppression toggles as needed in the configuration table. Net result being only one fixed part is active at a time.
Now perhaps this strategy is second nature to old OnShape hands, but as a newbie coming from Catia and SolidWorks, I cannot recall an assembly model I ever worked on in either of those environments that contained multiple fixed parts — that was a fundamental design no-no.
But at the very least in OnShape, the rule seems a bit more nuanced, allowing for multiple fixed parts so long as only one is active at a time per configuration.
See file STRUT KIT here. Side note: min-max limit positions used for angle and travel of strut nuts, with minimum 'usual' position, so 'reset' applied across all instances does a remarkable job. Approach seems to work satisfactorily in this application, since strut nut position is essentially cosmetic.
Any insights into…
• 'Configuration Hypothesis' or …
• Multiple fixed parts and the warning flag — can it be safely ignored? Or …
• More efficient OnShape configurations in general, or …
• Any way to drive multiple-selected limit positions to max or some arbitrary intermediate value, say with a Feature Script…
please advise!
Thanks in advance
Brandon W. Nichols, PE
Seattle, Washington
