MBD Step File Viewer
stuart_aspinallstuart_aspinall Member Posts: 17 PRO
Does anyone know a good free step file viewer that will show the MBD Info from the Inspection table. When I export the file to Step format and select AP242 format, with the Use Custom Annotation Text height set to 3mm, I try it in EDrawings, which just opens the model, doesnt show any annotations.
I just want to check that they are showing before sending Step file to manufacturers.
Thanks
Stu
