How to make a cube?
alex_vestasalex_vestas Member Posts: 68
How to make a cube? I started Sketch 1, selected Front plane, then Line
https://cad.onshape.com/documents/03e2c9415eb538a6b1dd7124/w/f24faf7b27d24311c5dec18f/e/e77f2cb5c9282e201fc37453
  • _anton_anton Member, Onshape Employees Posts: 532 image
    I'd start with our free courses: https://learn.onshape.com/
    Just use one of the rectangle tools, constrain the sides equal and to length D, then extrude to depth D.
  • alex_vestasalex_vestas Member Posts: 68
    Is there a way to convert drawings created with draw.io diagram software for making flowcharts/diagrams to onshape dawings use AI? It creates plain drawings.
  • Ste_WilsonSte_Wilson Member Posts: 582 EDU
    Why would you need to?
    You can export an svg from draw.io and import it directly into onshape.
    Yes, I can import it as SVG into onshape. But I need to get an editable Part studio and Drawing as result of import.
  • martin_kopplowmartin_kopplow Member Posts: 1,317 PRO
    I'm curious about the use case for this workflow. What are you trying to achieve? Draw.io is neither very accurate nor overly comfortable to use, so this would only make sense if you absolutely need to incorporate geometry provided by someone else into your designs. I could imagine placards, type or serial number stickers or other graphic elements.
    I ask because I have had similar cases, though not with Draw.io but other graphics apps.
    I find it convenient to use draw.io for my purposes, it's easy to use and I can quickly sketch a simple detail. It would be nice if this flat 2D drawing could be recognized and processes by AI and imported directly into onshape as regular native project, not svg image.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,635 PRO
    If you are sketching a "simple detail", why wouldn't you just sketch it directly in Onshape though?
  • bruno_cordeiro951bruno_cordeiro951 Member Posts: 2
    The answer to "How do I make a cube" being "Take a course, use ONE OF the rectangle tools, constrain sides equal and to length D, then extrude to depth D" exemplifies everything that is wrong with 3D CAD today…
    It's like it's built by engineers who are OK with the job security/hourly rate of clicking and typing 10 parameters for a single basic shape. Not built for designers sketching ideas, who just need to drag and modify a basic shape with 1 click.
    This is why people keep returning to TinkerCAD. Absolute usability blindness in the CAD space
    @bruno_cordeiro951
    This is possibly because enineers don't need perfect cubes so often.
    You could just use a feature script: CUBE by Evan Reese. Add it to your tool bar. That'll make a cube for you in one go.
    If you are after nothing but pushing things around a bit, though, then parametric CAD may just not be for you. Try Spaceclaim. That's direct modeling and allows pushing everything everywhere with only one tool, while still being surprisingly precise.
