Using the hole table in a drawing of a composite part
felix_fischer992
Member Posts: 7 EDU
I am currently drawing up plans for a new balcony, which includes drawings of two composite parts that also have a number of holes in them.
In order to keep the drawing somewhat tidy, I'd like to use a hole table, however it seems like this is not possible with composite parts(?). In the part studio, all the holes are listed correctly for my composite part, but when trying to add one to my drawing, I cannot select a view.
Is there any workaround to this?
Any help would be greatly appreciated!
I have the same issue in a welded fabrication that I'd like to use a hole chart for!
Is there a workaround for this that anyone has found or has an improvment request been made?
