Improvements to Onshape - April 3, 2026
mlaflecheCADmlaflecheCAD Member, Onshape Employees, Developers Posts: 203 image
edited April 6 in New in Onshape
The latest update to Onshape brings upgraded surfacing tools, new user interface preferences and abilities across the product, plus exciting new machine learning technology being implemented to help you make drawings faster!
CAD
BEZIER CURVES: SUBDIVISION SPLIT AND TRIM
Bezier curve editing is now more predictable. When splitting or trimming a Bezier curve, the original shape and curvature are preserved while maintaining the same degree of smoothness. Each resulting segment gains its own control points, enabling precise local edits without impacting the rest of the curve.
https://onshape.wistia.com/medias/9bkf5b0rv2
RULED SURFACE NORMAL TO A REFERENCE FACE
Create ruled surfaces normal to a reference face using curves that don't need to be adjacent edges of that face.
https://onshape.wistia.com/medias/lje3aakuk4
TABLE ACCESS VARIABLES FOR VARIABLE STUDIO
Variable studios now support adding variables from an imported table such as a CSV file. Users are presented with a new From Import variable type, where they will be prompted to provide the source and cell selection criteria similar to the recently introduced Part Studio variable support for imported tables.
To see examples of how to use these variables, you can see it in action when this was previously released for Part Studios.
Additionally, you can configure fields to extract different table values depending on your Onshape configuration. To further understand the depth of this functionality, we encourage you to review the help documentation. (edited)
https://onshape.wistia.com/medias/a8pfmqi3sw
SKETCH GRAPHICS PREFERENCES
Graphics preferences now include sketch display options.
https://onshape.wistia.com/medias/71fz4twcuy
SECTION VIEW ALONG STANDARD PLANES
Section views in support additional options for cutting along standard X, Y, and Z planes, giving you faster access to common cross-section orientations, especially in Assemblies.
https://onshape.wistia.com/medias/s8a89itwhn
COMMENTS WITH MODEL-BASED DEFINITION
Markup works with Model-Based Definition and the Inspection panel, capturing and preserving context within the markup.
https://onshape.wistia.com/medias/s466uu8c7q
DRAWINGS
BETA: REPLICATE ANNOTATIONS
This update sees the Beta release of Replicate annotations for drawings. Replicate annotations uses machine learning and probabilistic matching to automate the transfer of annotations, including dimensions, tolerances, layout, and placement, from one drawing view to another, even in a different drawing. Although it uses machine learning techniques, it only looks at the model at run-time when you invoke the command; It does not train on your data. We’re truly excited about this new beta technology and the possibilities it may unlock in the future. We encourage you to try it out and provide feedback on where it could be improved, what doesn’t work the way you expected, and what you would love to see next.
https://onshape.wistia.com/medias/kgto0ybo8n
ADDITIONAL UNITS
Onshape provides four new units to display on your detail drawings. These new units are Centimeters, Meters, Feet (with decimals), and Yards. These are available for the overall units, dual units, and overridden units. When displayed as dual or overridden units, the appropriate abbreviated units suffix will be displayed. Additionally, these four new units can be selected when creating a new drawing in Onshape as well.
https://onshape.wistia.com/medias/wh02mbbp64
DOUBLE NEGATIVE AND POSITIVE TOLERANCE BUTTONS
Onshape now provides buttons on the tolerance controls for double positive or negative deviations on your drawing dimensions and hole callouts. This makes it easier to add tolerances where both deviations must be negative or positive. This subtle improvement streamlines adding complex tolerances to your drawing dimensions.
https://onshape.wistia.com/medias/icc4bz44jd
DATA MANAGEMENT
TAB MANAGER USER PREFERENCES AND DEEP FOLDER NESTING
Tab Manager gains user preference controls and support for folders nested 10 levels deep from the root folder, giving teams more flexibility in organizing document tabs.
https://onshape.wistia.com/medias/afecwk6pzu
RESIZE BOM TEMPLATE IN COMPANY SETTINGS
BOM templates are resizeable directly in Company settings for large column counts.
https://onshape.wistia.com/medias/pnxq4sttc8
CUSTOM PROPERTY OVERRIDES FOR PUBLIC DOCUMENTS
When using Public parts and inserting them into documents, you can customize properties like part number and descriptions to match your company standards while preserving the original author's data. The override values are specific to the user or company, automatically carry forward to new versions, and integrate directly into build materials.
https://onshape.wistia.com/medias/jl4av2ik40
CAM STUDIO
SPINDLE DIRECTION DISPLAY IN SIMULATIONS
CAM Studio simulation now includes visualization of spindle direction. By enabling Show spindle direction, users can clearly see clockwise or counterclockwise tool rotation directly in the graphics area.
https://onshape.wistia.com/medias/7m427yppll
COMPOSITE PART SUPPORT IN CAM STUDIO
Support for composite parts in CAM Studio has been enhanced to improve reliability. Selections remain stable, toolpaths calculate correctly, and setups behave as expected. Composite parts are ideal for fixtures and workholding, allowing multiple components to be brought in as a single entity for faster, more efficient job setup.
https://onshape.wistia.com/medias/8cwgd9ssgc
AUTO-SCALING 2D SELECTION ARROWS
Defining 2D contour toolpaths is now clearer and more predictable. Selection arrows for 2D contour operations automatically scale in the graphics area, making them easy to see at any zoom level. This improvement reduces ambiguity when defining cut direction, helping users avoid mistakes and work with greater confidence.
https://onshape.wistia.com/medias/9c3x1p96ik
UPDATED JOBS USER INTERFACE
Onshape CAM Studio has updated its Create job interface with new user interface elements that provide better consistency with the overall Onshape user experience.
https://onshape.wistia.com/medias/d5962x4hw0
PCB STUDIO
PCB HOLES TAG
Tag PCB holes or cutouts for metadata used in PCB Studio board exports and imports. Select geometry, define orientation, and add properties.  The PCB Studio presents holes from the tree and highlight in the graphics and the Component properties panel.
https://onshape.wistia.com/medias/c93470kafp
Please take a moment to try out these new features and leave your comments below. For a detailed list of all the changes in this update, please see the changelog.
Remember: The updates listed here are now live for all users when creating new Documents. Over the next few days, these features will also be available in Documents created before this update. Mobile app interface updates occur via the Apple App Store or Google Play Store and happen in the days following the update.
Regards,
Mike LaFleche   @mlaflecheCAD
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 903 PRO
    The updates to the bezier curve sketch tools will be much appreciated by our design department. They were getting sick of wrangling splines.
    I personally can't wait to explore the new tagging architecture and PCB studio improvements and find out which non-PCB things they'll be useful for.
  • MichaelPascoeMichaelPascoe Member Posts: 2,827 PRO
    edited April 3
    CAM studio is coming along nicely, good to see the UI improvements starting to hatch.🐣
    Happy Easter Onshape team! Thanks for the hard work.
    RENDERCAD
  • Caden_ArmstrongCaden_Armstrong Member Posts: 425 PRO
    typo in the api changelog
    API support for Ordinate dimensions!
    Its nice seeing update full of spring cleaning items. Shows the platform is constantly improving everywhere and not just focusing on big flashy features.
  • S1monS1mon Member Posts: 4,129 PRO
    The ability to properly trim and split Bézier curves is something I've wanted since they were added to sketcher. Thank you!
    (The lack of) sections through standard planes in assembly is something I have called one of the most user-hostile things in Onshape. Nice to see this one finally fixed. Hopefully it carries over to the lightweight view as well.
    The AI based (beta) drawing "replicate annotations" is exciting to see. I wasn't expecting this so soon from its recent preview.
    More units seems like one of those basic things that should have been there a long time ago, but I imagine it was more complicated than we imagined.
    The sketcher line-widths and color options are going to be interesting to try. I hope this makes unconstrained points easier to find.
    All in all many things that make Onshape a better place to be.
    edited April 4
    [BTW, The changelog currently shows an almost complete duplicate set of items for the latest release. Most likely a copy/paste error.]
    Edit: Fixed
  • aeromorrisonaeromorrison Member Posts: 82 PRO
    edited April 3
    Great improvements for ruled surfaces and Bezier curves! I'm also very excited about the new CSV-driven workflows as we need to interact with external codes all the time. I'd love to see similar workflows enabled for JSON format files.
  • RhettRobinsonRhettRobinson Member Posts: 213 ✭✭✭
    Really excited to test out replicating annotations, this could be a huge time saver in the wheel space. Happy to see quite a few things rolled out that have been wanted for a while!
  • david_mcmahondavid_mcmahon Member Posts: 40 ✭✭✭
    I love the new sketch graphics preferences! I am, however, confused by one thing. What are inactive sketches? If it means the linestyle of sketches that are turned on in the model (outside of sketch mode) it does not work for me. When I change the color of the inactive skethes none of the displayed sketches in the model, i.e. the ones not in sketch mode, change color.
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,132 PRO
    cm and m!
    edited April 4
    It seemed to me during the new x-section default plane demo, Michael was trying to hold back cracking up when he used the word "plane" inside of assemblies. 😂
  • MDesignMDesign Member Posts: 1,355 PRO
    Still deciding on a good color combo but WOW. So much easier to see this now..
  • mlaflecheCADmlaflecheCAD Member, Onshape Employees, Developers Posts: 203 image
    @nick_papageorge_dayjob yeah, it's true ;-)
    Regards,
  • shawn_crockershawn_crocker Member, OS Professional Posts: 979 PRO
    Replicate annotations is HUGE!🤯 I'm seeing the annotations poorly layed out somtimes but, seems like that will be easy for the AI to continue getting better at.
  • peter_lewis879peter_lewis879 Member Posts: 3
    Typo: “Uses are presented”
    @peter_lewis879 thanks, resolved.
    Regards,
    Would someone please confirm if the color option is working for Inactive Sketches in the new Graphics Preferences menu? The line width works for me but not the color.
    Works for me:
  • Cedric_EveleighCedric_Eveleigh Member, OS Professional, csevp Posts: 74 PRO
    "SECTION VIEW ALONG STANDARD PLANES"
    Thank you! Now I no longer need to create mate connectors to represent front, right, and top planes for section views.
    Thanks. After digging into this a little more, the issue with the inactive sketch color display looks to be part specific. It apears to only happen with an existing part that has a JPEG inserted into the sketch as a tracing image.
  • martin_kopplowmartin_kopplow Member Posts: 1,351 PRO
    Wow, that is a truckload and many I've been asking for. Any easter eggs anywhere? ;0)
  • brian_vanderbuschbrian_vanderbusch Member Posts: 4
    What an update! Nice work!
  • STEGSTEG Member, User Group Leader Posts: 140 PRO
    I love this update! 👏
    Any improvement that speeds up the drawing creation is more than welcome! 🤩
  • christopher_dziubachristopher_dziuba Member Posts: 113 ✭✭✭
    Oh wow! I can not wait to try that dimension tool!!
  • Urs_Egger_REACTUrs_Egger_REACT Member Posts: 126 PRO
    Appreciate also the smaller improvements like
    features like these make a CAD System mature. And I don't want to do workarounds for years. So keep improving also the minor topics to make. It is really appreciated a lot. It is much more important than the fancy AI stuff.
