Deform (New Custom Feature!) 🆕twist | bend | scale | morph | wrap | flex
MichaelPascoe
MichaelPascoe Member Posts: 2,947 PRO
edited May 4 in FeatureScript
CadsharpSpin.gif  CADSharp & logo-128.png RENDERCAD have sponsored a new custom feature:
Deform (Pascoe).png Deform
It deforms a parts and surfaces via profile sections or lattice grids along a path. Useful when you need to bend, twist, and scale parts after they have already been modeled.
Note: It is still a work in progress but I think its good enough for first release.
https://cad.onshape.com/documents/303775db976a02780499bec3/w/80a914faf16b9cdbd2f23c0e/e/0f0912aaf…
Special thanks to:
◉ RENDERCAD - Photorealistic product rendering.
◉ CADSharp - Professional CAD + software consulting.
  • Derek_Van_Allen_BD
    Derek_Van_Allen_BD Member Posts: 1,133 PRO
    Could it be? My 4 dimensional dreams realized at last? And I didn't have to write the whole thing myself? It's beautiful.
  • MDesign
    MDesign Member Posts: 1,466 PRO
    joey.gif 472.9K
  • MichaelPascoe
    @Derek_Van_Allen_BD There is still work to do. if you want a challenge, see if you can get it to work on the test studios.
  • EvanReese
    EvanReese Member, Mentor Posts: 3,082 PRO
    @MichaelPascoe what a madman! This is ridiculously cool to see. I'm going to need a tutorial on the UI. So many levers to flip and knobs to twiddle.
    I'll definitely poke around and see how it runs compared to the FFD concept that I did that lacked the surface stitching.
  • MichaelPascoe
    @EvanReese alright, yeah, needs a quick demo / tutorial. I'll try to whip one up later.
    @Derek_Van_Allen_BD It seems to do ok with main body protrusions but has difficulty with small protrusions and pockets or large pockets.
    Almost got the acanthus leaf test studio to work and then it digressed again and looks like it does now.
    Either way, this is at least a starting point (or a black hole) and the closest thing I've seen so far to a full deformation feature.
    S1mon Member Posts: 4,564 PRO
    This is both absolutely amazing and somewhat frustrating at the same time. I wish whatever underlying magic wouldn't make the surfaces so heavy and wouldn't do crazy things at the ends. This example is only using a simple single span degree 3 curve as the target, but the result is way more complex, and the ends are even heavier and more wobbly.
    I would also love to see a demo video. There are a zillion options.
    If it's the same magic as the tween surfaces magic, what's happening is the surfaces are being elevated and having knots inserted to match the deformation domains which is a necessary step to guarantee the resulting surfaces respecting locality of the driving geometry.
    Also if it's the *exact* same tween surfaces magic, I messed up some of the knot insertion logic and probably the points aren't being perfectly inserted in the intended regions. I can't actually look at the source until next week when I'm back in office after my trip to go play with some marbles.
  • MichaelPascoe
    edited May 2
    Ok, here is a demo video.
    Also cleaned the feature up a bit so the user interface is more intuitive.
    (The clean up was after the video unfortunately, but its the same functionality just less overwhelming now.)
    @S1mon this is first draft so expect some rough curvature. Will try to improve.
  • MichaelPascoe
    In case anyone wants to contribute to this feature, here are the areas it is lacking:
    • Concave faces and pockets
    • Small island protrusions on a side wall
    • Curvature heavy faces
    I recommend tossing it into codex gpt 5.5 or claude 4.7 and grabbing a coffee. 😎
  • Konst_Sh
    So regarding hight curvature region sampling I might have some aproach used in curve transform features - vary point sampling density based on accumulated curvature function. For curve it would look like first take a number of evenly spaced curve parameters and corresponding curvatures, create a somehow a function that interpolates from accumulated sum of curvatures up to specific parameter to that parameter. That function has a property that given evenly spaced range of points on curvature axis it will map them into into unevenly spaced curve parameter points with the more dense regions where the curvature is higher. For the 2d case of face sampling this will likely require 2d interpolation dependency
  • wille_j
    wille_j Member Posts: 135 ✭✭✭
    wow, this is really impressive 🤩 well done!
  • tunahan_döner405
    tunahan_döner405 Member Posts: 7 ✭
    Thank you for the video, it was really helpful.
    Seeing how it works in practice made things much clearer, especially in understanding the overall workflow. I appreciate the effort you put into it!
  • MichaelPascoe
    will probable add some of your features @Konst_Sh to the example repo for it and have it optimise. I should have done that from the start but this was supposed to only be a proof of concept; then;it actually worked lol.
    The Almighty Algorithm must be tracking my search history and cookies very closely because Google just served me a recommended thread from a FreeCAD development branch on GitHub attempting a generalized deformation feature as well. Different language and kernel obviously but at least it's open source to be able to poke around at and compare / contrast to this approach.
  • MichaelPascoe
    edited May 4
    forgot to push a version for the improved UI. there, its updated now.
  • roman_jurt190
    roman_jurt190 Member Posts: 89 EDU
    wow! thank you! very cool! I'm give it a try soon!
    Started doing my poking around. It actually looks like this takes a fundamentally different path than the FFD experiment and surface tweening stuff I did previously and does some aggressive sampling and reconstruction methods that are probably the cause of the weird surface quality artifacts seen in the above images. It's a closer attempt than I had, but I'm gonna see if switching around some of these lower level functions can improve the performance and stability of the feature.
  • MichaelPascoe
    edited May 5
    Update 🎉
    • Added path support for faces. Now you can easily wrap onto a surface.
    • Added preview mode. This pauses the heavy calculations while you move the manipulators around.
    • Added position manipulators so that you can move the part around on the path or surface.
  • MichaelPascoe
  • sebastian_glanzner
    sebastian_glanzner Member, Developers Posts: 498 PRO
    People in 100 years will remember this FeatureScript as the first sign of the AI singularity
    23616.png 1000.3K
  • MichaelPascoe
    Lol! There should be a bit more space between the Orange and the Green🤣
    The y-axis is logarithmic, which makes them even closer 😁
    The original image comes from Tim Urban’s Wait But Why series “The AI Revolution,” published in January 2015.
