Merging sketches
Hello everyone!
   I'm trying to model an engine block. I have two sketches which I have derived from separate blueprint drawings. I created them in different Parts Studios. Now I would like to know if there is a best practice for getting the sketches in to a single part studio. I see the copy function of the sketches, however I don't know how to paste.
Here is a screen capture of what I have so far:
https://drive.google.com/file/d/0B4Rd9zUi5v65Z25zZ1FGdW43MW8/view?usp=sharing
Thanks in advance!
-James
  • Narayan_KNarayan_K Member Posts: 379 ✭✭✭
    @ james_wiger23610  , another method is by using "Derived" option. In this method you can insert the sketch from other part studios of same document.
    After inserting the sketch will be positioned as per previous part studio orientation.
  • nofa_alghizawinofa_alghizawi Member Posts: 1
    On the bottom left-hand corner click on where it says "parts", then select the parts that you want to merge, and then click "Boolean".  and that should help.
