Merging sketches
Hello everyone!
I'm trying to model an engine block. I have two sketches which I have derived from separate blueprint drawings. I created them in different Parts Studios. Now I would like to know if there is a best practice for getting the sketches in to a single part studio. I see the copy function of the sketches, however I don't know how to paste.
Here is a screen capture of what I have so far:
https://drive.google.com/file/d/0B4Rd9zUi5v65Z25zZ1FGdW43MW8/view?usp=sharing
Thanks in advance!
-James
Thanks in advance!
-James
shashank_aarya Member Posts: 265 ✭✭✭
Hi James, see the below method to copy and paste the sketch from one part studio to another
For pasting the sketch it is required to select appropriate datum plane or planer surface.6 -
viru Member, Developers Posts: 619 ✭✭✭✭
@james_wiger23610 , Refer below video to use sketch and part from different part studio. After pasting you should only need to add a coincidence and vertical or horizontal or angle dimension to fully constrain.
6
After inserting the sketch will be positioned as per previous part studio orientation.
