Remapping UV Curves on a Revolve Flat Surface?
ry_gbry_gb Member, csevp, pcbaevp Posts: 261 PRO
Is there a way to remap a revolved flat surface to make the coordinates polar rather orthogonal? I was trying to use Attractor Pattern on a revolved surface (not a full 360 revolve. I'm aware of the limitation) and realized that the underlying grid was perpendicular UV lines and giving me undesired results. The profile for the image on the right is a line that's tilted by 1 degree for demo purposes.
Ramon Yip | glassboard.com
  • S1monS1mon Member Posts: 4,346 PRO
    If you revolve something at a microscopic angle from normal to the axis, it will create the surface with the desired UV structure. The minute you do something that could be flat, Parasolid will try to be helpful and make it a simple grid.
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 406 image
    edited June 16 Answer ✓
    I may be overthinking this… but try this ;)
    https://cad.onshape.com/documents/b4a6390ff08540b94b378e64/w/ae411fd2ec988dc3efd3f8a2/e/16153c47ea2e417695cdef36
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,269 image
    You'd need to replace the plane with a planar NURBS surface, I can't think of a way except for that…
  • ry_gbry_gb Member, csevp, pcbaevp Posts: 261 PRO
    So it's just the Parasolid kernel doing its thing? Rhino was pretty explicit about the surface, but @ilya_baran you mentioning NURBS makes sense.
    I just tried importing a Rhino file into my part studio and while the surface did import with a seam, the grid is still orthogonal. Overall, this isn't a big deal to me, but just a quirk I found in the software. I'm sure there are workarounds for this that don't involve UV.
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 1,039 PRO
    There have been a number of times I've wished for the ability to have some kind of curvature flow on flat surfaces and thought about resorting to tweaking one minor corner of the surface and projecting back to the plane. Tween Curves is a partial solution but I'm not entirely happy with that either for some use cases.
    edited June 16
    @GregBrown 🤣 madness
    But this does do what I asked for. It's really mainly for things like attractor pattern where the UV layout matters. I also saw you made it in 6 minutes. Was this done using an LLM? If so, that's really impressive. Also impressive if you figured all that out in 6 minutes as well.
    Also, lol @ over 9000
    Ha! Yes, I appeared to do this quickly as it was copied over from a different doc that I had been working on. And yes it was part of some MCP testing… I also happen to have a couple thousand lines of NURBs helper functions from those MCP tests and could pull some hints from that, which bootstrapped things nicely.
    I would love to get some MCP support for featurescript going cause I'm finding that any time there's a hot new model of the month they have this tendency to ignore all of my .md files laced with all of my helpful instructions and I'm forced to spend a little bit of quality time reeducating the newest Claude about featurescript.
    Just is case it’s not clear from all the different posts I’ve made, I would love to try out the MCP support.
  • billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,157 PRO
    edited June 17
    @ry_gb I looked up Attractor Pattern for ai and now kinda understand your question.
    I believe you got the answer especially if claude sent Greg an email asking him to build the geometry😆. If it did I'd start using claude. Possibly in your next prompt you might want to add "without human interaction".
    If you're prolific with rhino and looking into Onshape, Greg created a feature to answer your question using feature script. We need more surfacing guys over here and would love to have some of that rhino hot sauce over here if you would.
    There's no AI hooked up to create geometry yet. With the wiggle cursor coming, I suspect we'll see that capability soon. But, I believe most would expect a trimmed surface from your prompt and therefore the original grid would be the most common solution. You would definitely need to provide more context to generate the feature script Greg created using ai.
    edited June 19
    About ai and Onshape- ai works very well with Onshape because OS is a cloud based system and has a tremendous source of data to learn from. It's nothing like desktop systems that are locked down behind firewalls and coop up on hard drives that aren't exposed to the cloud. The feature script source files and all documentation are exposed in the cloud.
    I'm using ai to write fs all the time and it seems to have a deep understanding of fs capabilities. Recently I asked ai to recommend a code editor that didn't use files and controlled revision like Onshape. It knows the branching & merging capabilities very well and gets that I'm looking for a non-file based version of git. It did come up with a solutions.
    With ai it's getting to the point where it's better to craft a prompt rather than looking into OS's help when you have an OS question.
    If you're looking for a cad system to use with ai, OS has the largest dataset exposed to train ai models and will beat any desktop cad system.
    @S1mon I haven't loaded it locally and was trying to run a cloud instant. Google and deno use it and both are cloud instances. It seems to be the standard these. I'm trying to remove files from my life and store stuff in a database instead.
    I will install it locally, deal with files and add the VSIX extension, thanks, I'm excited.
    edited June 24
    Sorry, was hoping I could vibe code some featurescript inside vscode. I'm supposing it's coming.
    Instead I found "File System Access API" and how vscode is trying to bridge the desktop to the cloud. 😕
    Sorry. I have no idea. We’ve gotten pretty far off the original topic here and I don’t know anything about vscode.dev.
    🤣 I wasn't gonna say anything, but now that you mention it…
