Importing off thingyverse
I am a junior in high school and need help starting using my own project and have no cad experience, but for now I plan on using a "turtle shell racer high power edition" from thingyverse but i have experience the issue of the document showing nothing when I open the document to edit so a larger battery will fit. Please help.
-Thank you very much
Brandon Pauley
Brandon Pauley
https://cad.onshape.com/help/Content/translation.htm
https://forum.onshape.com/discussion/1147/failed-to-import-projects-from-openscad-to-onshape#latest
there are a number of options available to convert your STL to something more "CADish" (as @andrew_troup mentioned). Run a search for "STL to STEP" (for example) and you will find a lot of options.
