Getting extraneous lines after exporting a drawing to pdf
colin_dalycolin_daly OS Professional Posts: 37 ✭✭
Has anyone else gotten some extra lines on their drawing after exporting to pdf?? I can't think of an explanation for this bug..
  • colin_dalycolin_daly OS Professional Posts: 37 ✭✭
    I forgot to mention, the extra lines are showing up in my detail views only.
  • brucebartlettbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,137 PRO
    edited December 2015
    Maybe a bug with detail view's.
    Share with support?
  • john_mcculloughjohn_mccullough Moderator, Onshape Employees Posts: 38
    We found a problem like this which only showed up with one face in one model. The detail view had some extraneous lines from a round (fillet) face at the base of a boss. The fix for this will be in release 1.40.
    I have not seen a report come in for your issue. There could be another case with special geometry in your model which is also generating these extra lines. If you continue to see it please share a document with us so we can get your case fixed.
    Sounds like my issue is the same, it occurs on one face, around a round fillet.  I will wait for the the new release, thanks!
