Plane tilt
lucymarie_manteselucymarie_mantese Member Posts: 24
edited December 2015 in Using Onshape
Update:  I tried inserting a tilted construction line and using the "Line Angle" option and that seems to be working to give me the tilted plane that I am looking for.
I'd appreciate help with inserting a tilted plane.  I've tried to apply some of the suggestions from other discussions in the forum but am having trouble with my application.  I attached a screen shot of the part.  I would like to insert holes onto the slanted surface and at the draft angle. I think I need to generate a plane tangent to that surface to sketch the holes.  To generate the plane I'm trying to use the "Line Angle" function but am not correctly choosing the correct plane/sketch combination.   Thanks for any guidance.
