What is a valid section view snap point?
steve_maietta
Member Posts: 54 PRO
in Drawings
Hello, I am drawing some plans with section views and trying to put the section views where I want them, but can only drop them where the orange box appears. They are forced to certain points. How can I define these points myself? I tried adding points in a sketch, but couldn't use these points in my drawing view.
thanks for any pointers as to the behavior of the section view tool.
~Steve Maietta
~Steve Maietta
brucebartlett
Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
Steve, looks like you got a result, however my intent was to create snap points without the extra parts and a assembly by just split 1 face.
2 -
john_mccullough
Moderator, Onshape Employees Posts: 38
Bruce's method works well because it generates separate edges along the top edge of his model. Even though those model edges are still splines, whihc become polylines in the view, the end points of each of those polyline edges are valid associative snap points in the drawing.5
Currently the best work-around for this is to place the cutting plane line "in space" near the location you need it. It will not be associative to the model, but should allow you to create the section view needed. This type of cutting plane will stay associative and move with the view.
So I tried what (I think) you meant. I created a sketch right along my model but not actually part of it. This sketch was 4, 2 inch line segments one after another. (I'd like to have a section view every 2" in my drawing) I went back to the drawing, regenerated the part and still can't snap section views to these points. Hmmmmmmm...? What exactly does OnShape look for to find a snap point?
(Edit - I moved the sketch so it is on the actual part, still no snapping)
~Steve
May be useful to be able to dimension where the section view lies, like how we dimension where lines are in sketches.
Heres the file (Public)
https://cad.onshape.com/documents/4a3090c111204005a035c899/w/c0478464d35e42f282b61dad/e/e1c01e32f68c409c8bc1c3b3
Hull 2 is the part and Hull Plans is the drawing.. Anyone care to give it a shot? Create a section view every two inches?
thanks
~Steve
I split the hull @ the planes then created an assembly from those parts. With a drawing from the assembly you can create a section view at the end of each part. Here's a link. HTH
~Steve
