Rendering - OneRender
namleknamlek Member, Developers Posts: 5 ✭✭
I find that I can get decent results using OneRender. Here are some of my samples:
My first attempt
Sample 1
Sample 2
Sample 3
Sample 4
Salt/Pepper Mill
    michał_1michał_1 Member, Developers Posts: 214 ✭✭✭
    Nice, did you try other render apps?
    I tried all the integrated rendering apps.
    For me, I found OneRender to give the best results and it seemed the most versatile of all the apps.
    The lack of pre-defined materials in the MiGenius Reality Server app meant it took more work to get reasonable results, and I never really knew whether I was responsible for stopping the server.
    For some reason I couldn't get Clara.io Vizualizer to work properly after it started producing errors when I added it to my document so I gave up and went back to using OneRender.
    You should give Clara.io another chance, it's most developed one from integrated. Just open your file in editor, not visualizer.
    thanks for the comment about Clara.io editor ... I'd missed that
    I found out that there are a number of keyboard shortcuts you can use with OneRender, which may be useful to others.
    Objects
    <ctrl> A  Select All the objects (Note: if an object is already selected when you use <ctrl> A it will select all the objects which use the same material)
    ESC  Deselects any selected object(s)
    <ctrl> left-click to select multiple objects
    If one or more objects are selected then the following shortcuts are available
    R  Rotate the selected objects(s)
    T  Translate the selected object(s)
    S  Scale the selected object(s)
    <ctrl> c  Copy selected object(s)
    <ctrl> v  Paste selected object(s)
    Camera
    <ctrl> n  Add new camera
    Z  Zoom to theselected object
    .   (the dot  key) Sets the camera  target to the selected object
    Panels
    <ctrl> L   Open Lights panel
    <ctrl> M  Open Materials panel
    <ctrl> P  Open Camera panel
    With OneRender I had mainly problems with UI and I was missing texture mapping... also tessallation is to rough.
    joe_dunnejoe_dunne Onshape Employees, Developers, csevp Posts: 198
    Very nice renders....
    Joe Dunne / Onshape, Inc.
    manuel_garciamanuel_garcia Member, Developers Posts: 3
    Hi Mick (@namlek), thanks for your comments. I'm glad you found your way to create nice renders using OneRender.
    Maybe you would be interested in testing our "Walkthrough video render" feature. If so, just let me know.
    If there is anything we can help you with, just drop us a line.
    Best,
    Manuel.
    Manuel Garcia
    OneRender - CTO
    Hi Michal (@michal_1), I'm very sorry to hear that. About texture mapping, certainly, we are working with the Onshape team to find a better way to handle this (mainly, it is an issue with the UV mapping). We have found that certain objects don't have a good quality UVs, we (OneRender and Onshape) are looking for a solution. I'll keep you posted.
    About tessellation, OneRender only decimates data for the web-viewer but it uses the full data for rendering.
    Let me know if you find any other issue, we are happy to help.
    Best,
    Manuel.
    Manuel Garcia
    OneRender - CTO
    jo_lpjo_lp Member Posts: 1
    Excuse me for bringing back this old thread@namlek but I wish to know which format did you use to export to onerender in order to get those results? I used .stl with very poor results and OneRender doesn't seem to support the other formats that Onshape works with.
    Paul_ArdenPaul_Arden Member, Onshape Employees, Developers Posts: 166
    Just to note, you can manually stop the server if you like but if you don't have any rendering activity it will terminate automatically after 5 minutes of inactivity.
    We are working on a new application with easier to use functionality, the application is a very thin layer on top of the rendering and conversion engine which can be enhanced over time. Over the next few months we hope to role out a significantly improved application.
    Hi Jo,
    You shouldn't been thinking in 3D formats while using Onshape + OneRender since OneRender retrieves Onshape native data. If you could tell me a little bit more about your project, then we can help you to get better results. Remember that you can reach us through your account manager or via chat support (inside OneRender, in the left-bottom -> Help menu).
    Best,
    Manuel.
    Manuel Garcia
    OneRender - CTO
