Rendering - OneRender
I find that I can get decent results using OneRender. Here are some of my samples:
My first attempt
Sample 1
Sample 2
Sample 3
Sample 4
Salt/Pepper Mill
My first attempt
Sample 1
Sample 2
Sample 3
Sample 4
Salt/Pepper Mill
1
projektowanieproduktow.wordpress.com
For me, I found OneRender to give the best results and it seemed the most versatile of all the apps.
The lack of pre-defined materials in the MiGenius Reality Server app meant it took more work to get reasonable results, and I never really knew whether I was responsible for stopping the server.
For some reason I couldn't get Clara.io Vizualizer to work properly after it started producing errors when I added it to my document so I gave up and went back to using OneRender.
Objects
<ctrl> A Select All the objects (Note: if an object is already selected when you use <ctrl> A it will select all the objects which use the same material)
ESC Deselects any selected object(s)
<ctrl> left-click to select multiple objects
If one or more objects are selected then the following shortcuts are available
R Rotate the selected objects(s)
T Translate the selected object(s)
S Scale the selected object(s)
<ctrl> c Copy selected object(s)
<ctrl> v Paste selected object(s)
Camera
<ctrl> n Add new camera
Z Zoom to theselected object
. (the dot key) Sets the camera target to the selected object
Panels
<ctrl> L Open Lights panel
<ctrl> M Open Materials panel
<ctrl> P Open Camera panel
Maybe you would be interested in testing our "Walkthrough video render" feature. If so, just let me know.
If there is anything we can help you with, just drop us a line.
Best,
Manuel.
OneRender - CTO
About tessellation, OneRender only decimates data for the web-viewer but it uses the full data for rendering.
Let me know if you find any other issue, we are happy to help.
Best,
Manuel.
OneRender - CTO
We are working on a new application with easier to use functionality, the application is a very thin layer on top of the rendering and conversion engine which can be enhanced over time. Over the next few months we hope to role out a significantly improved application.
You shouldn't been thinking in 3D formats while using Onshape + OneRender since OneRender retrieves Onshape native data. If you could tell me a little bit more about your project, then we can help you to get better results. Remember that you can reach us through your account manager or via chat support (inside OneRender, in the left-bottom -> Help menu).
Best,
Manuel.
OneRender - CTO
